Survey123 Collapsed Group - Making the Name Clickable
4735
7
06-05-2018 04:48 AM
FinnianO_Connor
When a group in Survey123 has its appearance set to compact, it is necessary to click a small grey triangle at the left hand side of the group name to expand the questions. Many users have raised this as an issue internally when we roll out forms as it can be tricky to actually expand the group. Is it possible to have the entire row 'clickable' so that a user can tap anywhere within that row to expand the group?
Cheers,
Finnian
Survey123 expand group icon
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Finnian,
Thanks for the suggestion.  This is logged as ENH-000106588 in the Esri Support system; the Survey123 will consider this with other enhancements as we plan future releases.
JamesTedrick
Hi Finnian,
FinnianO_Connor
Thanks for the reply James. Hopefully this finds its way in to a release in the near future.
Finnian
StephenCox
This would be a huge help!
BradenBurkholder1
Any update on this enhancement request?
Thanks!
BrandonArmstrong
Hi Braden,
This enhancement will be included with the next release of the Survey123 Field App, and it can be tested now with the latest beta provided via the Early Adopter Community.  Please let us know what you think.
Best,
Brandon
DougBrowning
MVP Esteemed Contributor
I vote for doing this to ALL inputs.  For example a horizontal-compact a user should be able to tap anywhere on the label.
A common user complaint is all the buttons are too small when you have big dirty hands and are out in the sun.
Thanks!
paolavincentfl
Any update on this?
