Layer - Poor Performance
2631
8
06-01-2018 08:11 AM
ChrisHolmes
I have a layer, looks like the attachment below. I would like to publish this as a map service to use in a web map application. It will only be for display purposes/background. But performance is quite poor when running it through mxdperfstat, mostly the three query layers. Looking for some ideas on possibly how to improve the performance or maybe a better way to view/use the layer. These poor results even occur at a scale of 1:1000. I would like to be able to display the legend also.
thanks
Here's a snapshot of the mxdperfstats results:
MichaelVolz
Esteemed Contributor
Can you provide some detail on the architecture of your query layers (e.g. database source and version, does the query layer source use joins between tables)?
ChrisHolmes
Thanks Michael. If I click on the layer properties, I can see that the source is our corp sde database:
If I click on Change Query I see:
This works fine on desktop where it was originally designed for and used. Recently it was handed over to me to use it in a web appbuilder application, and it's just too slow.
MichaelVolz
Just out of curiosity how many records are in your query layers?
What version of ArcMap are you working in?
ChrisHolmes
Thanks Michael.
We are using ArcMap 10.5.1
Low density query layer: 281144 records
Medium density query layer: 17624 records
High density query layer: 15089 records
MichaelVolz
Is the Oracle database you are using a complete SDE database or is it just an Oracle database that has ESRI spatial libraries installed so the data can be spatially enabled with ST_Geometry?
ChrisHolmes
It is a complete SDE database.
ChrisHolmes
Any further thoughts anyone?
thanks
TeroRönkkö
Did you ever get solution for this? We ran into situation where once querylayer that worked adequately is now making arcmap unresponsive and rendering takes upto 1200 seconds per refresh. I think arcmap is doing somekind of full table scan on the data on almost every pan of the map and as it is based on versioned views it takes a looong time to both fetch and draw the data.  -> We are moving to precalculated materialized views.
