How to use a REST service in Python - DownloadRasters_management
5074
10
05-31-2018 10:34 AM
BobBistrais
I am writing a Python script with uses the DownloadRasters_management tool.  I want to use an Image Service from one of our servers as the input.  According to the documentation, the format is:
arcpy.DownloadRasters_management (in_image_service, out_folder, {where_clause}, {selection_feature}, {clipping}, {convert_rasters}, {format}, {compression_method}, {compression_quality}, {MAINTAIN_FOLDER})
for the in_image_service, I entered the URL to the service in quotes, e.g. "https://myserver/myimageservice/ImageServer"
-When I run the script, I get an error message "pythonw.exe has stopped working.  A problem caused the program to stop working correctly.  Please close the program".
-I also tried using the same URL to the service in ArcGIS Desktop, DownlaodRasters_management tool.  This gives me the message that the tool ran "successfully", but in fact, there is no output.
Any suggestions on how to properly format the URL to the service?
DanPatterson_Retired
Bob, can you show the exact code you were using and not just the help file format string
BobBistrais
Yes, here is the actual code:
arcpy.DownloadRasters_management ("https://gistest.maine.gov/arcgis/rest/services/Elevation/Maine_Elevation_DEM_Aggregate/ImageServer", "C:/ImageDiscoveryNextGen/TempOutputs/imagedata0", '', "C:/ImageDiscoveryTest/SelectionGraphic.shp")
hmmmm. just make sure that C:/ImageDiscoveryNextGen/TempOutputs/imagedata0 is a folder that actually exists.
Try to use "" rather than '' for unspecified parameters (shouldn't make a difference, until it does)
and the shapefile extent overlaps the inputs and is in the same coordinate system.
And you omitted the import arcpy, I presume for brevity
BobBistrais
Yes, the import arcpy is at the top of the script, sorry I didn't paste that here but it is in the script.  The output file does exist, and I changed that single quoted blank to double quote.  And the SRS matches as well.  I also tried a different image service and got the same error.
Time to flag ArcGIS REST API‌ since I am not sure it is a python issue since it can't perform, hence it fails
JoshuaBixby
MVP Esteemed Contributor
If you look at the examples in Download Rasters—Data Management toolbox | ArcGIS Desktop , the service names all end with "?", so you might want to try appending a question mark at the end.  I also have some suspicions about your where clause.  I haven't worked with this tool before, but it could be an empty string generating a where clause that returns nothing.  Try leaving out the where clause and passing selection_feature as a named argument.
BobBistrais
I tried with and without the question mark, but no difference, also no luck with the where clause.
BobBistrais
I also tried this code using a mosaic data set instead of the service URL.  All the rest of the string was the same, but it worked when using the MDS.
So that suggests that it has something to do with the URL to the REST service.  I think Dan has a good suggestion to flag https://community.esri.com/community/developers/web-developers/arcgis-rest-api
JoshuaBixby
Since the Geoprocessing Tool is calling a web service, you could use Fiddler or a similar tool to profile the calls to the server and see what, if any, errors are being returned from the server.
