Are graphic elements within data frames accessible using ArcPy?
1005
07-24-2019 10:06 AM
ZoeZaloudek
I'm attempting to adjust a graphic element that I have in a MXD using ArcPy.  However, it is not an element from the page layout (layout view), it is within a data frame (data view).  I can't use the ListLayoutElements function because: "ListLayoutElements only returns elements from a page layout and not map annotation elements that may exist within a data frame."
There's no way to accomplish this task manually - my script needs to export many images and the extent of the data frame changes for every image.  Big picture: I'm trying to work around label overprints of an inset data frame just like the "Don't ignore data frames" problem in this thread:
How do I force Maplex to ignore transparent polygons, not ignore Data Frames?
