Edit MapManager to query FeatureAcces Service with URL Parameter
2107
5
05-30-2018 07:25 AM
Juan_ManuelAngel_Cuartas
Hi Friends, if some one can help me or give any idea how i can query the Feature Access Service in a WebApp Builder if i pass the parameter in the url with the OnLoad Event, i have this code idea:
url = http://localhost/webApp/Index.html?CountryCode = 1
I get the code with javaScript Code and then i pass to QueryTask in JavaScript in the MapManager
mapMain.graphics.clear();
var x = "URL PARAMETER GET"
//alert(x);
var query2 = new Query();
query2.outFields = ["CODIGO_CATASTRAL,MUNICIPIO"];
query2.returnGeometry = true;
query2.where = "COUNTRY_CODE= '"+x+"'";
queryTask2.execute(query2, CreateGraphics);
If some one Have any idea of how to do that its be very helpfull thanks !
RobertScheitlin__GISP
Juan,
   In the MapManger.js file you have access to this.urlParams that will give your the url parameters.
Juan,
Juan,
   Did you try my suggestion?
Hi Robert Thank you, i forget answer and mark as correct , yes its work perfect, when i call the parameter but i have another problem, I need to set that param value to make a DefinitionQuery to a layer that was add in the webMap, the problem is when i use the getLayersId i just get the basemap id but not the other layer to setDefinitionQuery, do you have any idea ?
Juan,
   If the layer if a FeatureLayer then you have to use the maps graphicsLayerIds property instead of the layerIds property.
Robert Thank you so much, i can query with the GraphicLayerIds and works perfect !
