Select by attribute of a polygon
2109
05-25-2018 05:18 AM
GideonDalrymple
Good day,
I have a layer of points along with a polygon shapefile which has multiple polygons which cover these points. Each polygon has a unique attribute. Is there a way to select points based on the attribute for a certain polygon in that polygon shapefile ?
regards
DanPatterson_Retired
you can 'Join' based on attributes between the points and polygons.
you can do a spatial join and/or a select by location to get points within polygons, then do a subsample ( select by attributes) from the selection.
Maybe if you show what you are trying to accomplish, other methods can be put forth
Shared to Geoprocessing‌ in case others have different suggestions
JoshuaBixby
MVP Esteemed Contributor
Is this something you will do a few times here and there, or is it something that will become part of a standard workflow and done repeatedly?  If the former, this seems like a fairly straightforward 2-step process:  Select By Attribute followed by Select By Location.  Use Select By Attribute to select the polygon(s) in question, and then Select By Location to find the points the selected polygon intersects.  If you want to create new data sets or update data, i.e., not just select data, Dan's Spatial Join suggestion might work better.
