Load a shapefile as orders in VRP using arcpy
1223
05-25-2018 03:03 AM
sotokan80_
I' m facing the following issue when trying to load a shapefile as orders in VRP solver using arcpy.
The code that i m using:
inOrders = "sortedStops"
orders = arcpy.GetParameterValue("SolveVehicleRoutingProblem_na",0)
orders.load(inOrders)
the errror message that i get;
File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\arcobjects\arcobjects.py", line 1042, in load
return convertArcObjectToPythonObject(self._arc_object.Load(*gp_fixargs(args)))
RuntimeError: RecordSetObject: Cannot open table for Load
The input shapefile has the following attribute table, which is of course doesn't resemble orders attribute table.
Any suggestions?
Tags (3)
sotokan80_
i found solution to my problem using MakeVehicleRoutingProblemLayer  and arcpy.na.AddLocations instead of SolveVehicleRoutingProblem_na. Thank you very much, for your reply.
DanPatterson_Retired
What does your orders file look like? It appears to require specific inputs
http://pro.arcgis.com/en/pro-app/tool-reference/network-analyst/solve-vehicle-routing-problem.htm
sotokan80_
ok, but how am i supposed to make my orders file with the same format? Another issue is that orders attribute table's fields have many characters whilst mine cannot exceed 10.
sotokan80_
