esri/geometry/projection fails to load in JS module (404 error)
1753
05-23-2018 07:36 AM
DirkVandervoort
JSAPI4x
I keep all my js code in a module (main.js) that loads when the page loads. I want to do some client-side projections - I'll need to include esri/geometry/projection.
Unfortunately including esri/geometry/projection in a defined module thrown a 404 error:
dojo.js:23 GET https://js.arcgis.com/4.6/esri/geometry/projection.js 404 ()
I can successfully load esri/geometry/projection in index.html - however I need to project in main.js.
I'm not sure if I need to include other dojo or esri modules in order to include esri/geometry/projection.
Make sense?
define(
 "dojo/_base/declare",
 "dojo/_base/lang",
 "esri/geometry/geometryEngineAsync",
 "esri/geometry/projection",
 "esri/identity/IdentityManager",
 "esri/tasks/QueryTask",
 "esri/tasks/support/Query",
 "esri/Graphic",
 "esri/layers/GraphicsLayer",
 "esri/geometry/Polygon",
 "esri/geometry/Polyline",
 "esri/WebMap",
 "esri/views/MapView",
 "esri/views/2d/draw/Draw",
 "dgrid"
 function(
 declare,
 lang,
 geometryEngineAsync,
 projection,
 IdentityManager,
 QueryTask,
 Query,
 Graphic,
 GraphicsLayer,
 Polygon,
 Polyline,
 WebMap,
 MapView,
 Draw,
 Grid
 return declare(null, {
 aGeometry: null,
 constructor: function () {
 // console.log("constructor");
doSomething: function(){}‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
MVP Esteemed Contributor
The projection module was added in 4.7, but you're using 4.6
KenBuja
