Reverse Proxy
2962
05-15-2018 03:25 AM
TorstenSchramm
i am using a iPad in our internal company wifi.
Our Internet connection go over a reverse proxy. I am able to connect to the login formular.
But the problem is to download my surveys because survey want to connect directly to the form urls (not over our proxy server). Our firewall blocked the download.
Is there a solution to configure in the app (not in the wifi setting from the iPad) to use a proxy ?
Thx
Torsten
by Anonymous User
Not applicable
Hi Torsten,
It is not currently possible to set a proxy in the Survey123 app, this needs to be done at the device level.
We are currently investigating the use of MDM (mobile device management) software to configure settings on a per app basis, using app config files. By doing this it may be possible to set the proxy via an MDM profile and push it to the device, so that only that app gets the proxy. If you have access to MDM software you may be able to test this out?
Phil.
HélèneTouyéras
Hi Phil & Torsten,
My organisation has the same issue. We tried to catch the URL called by S123  when login-in/retrieving the list of available surveys, but we were not successful.
Would you have any hint/pointers for us? The idea would be to adjust proxy setting to let those URLs through (I think - I am no IT specialist, so this is my basic understanding of it!)
Note that we successfully use Collector on the same enterprise network, because the URLs are exposed.
Many thanks!
Hélène.
