How to set default values in widgets
2944
05-11-2018 05:03 AM
MarijeKootstra
I want to set some default values to parameters to the 'Plan Route' option of the 'Analysis' widget in Arcgis Web App Builder for Developers. For example, in the 'Plan Route' option I want the parameter "Amount of walking routes from start to end point" automatically set to 1. In addition I would also like the travel mode to automatically be Walking Time and the 'Include route layers" box to be automatically checked.
Does anyone know how to do this and would you please explain to me how to set these values.
An example of what I would like to change and my widget.js source code is attached are placed in the attachment.
RobertScheitlin__GISP
I am not seeing a "'Include route layers" checkbox on my widget?..
MarijeKootstra
Hello Robert,
It is on the bottom of the Plan route widget
Marije,
   It seems that the widget defaults to walking already. Here is the other changes. Make the following changes to the _switchToAnalysisTool function lines 116 - 130:
    _switchToAnalysisTool: function() {
      domStyle.set(this.toolLoadErrorNode, 'display', 'none');
      this.shelter.show();
      require([this.currentToolSetting.dijitID], lang.hitch(this, function(AnalysisDijit) {
        if (this.currentAnalysisDijit) {
          //this.currentAnalysisDijit.destroy();
          if(typeof this.currentAnalysisDijit.clear === 'function') {
            this.currentAnalysisDijit.clear();
          this.currentAnalysisDijit = null;
          domConstruct.empty(this.toolCtr);
        var isPortal = !portalUrlUtils.isOnline(this._getPortalUrl());
        var args = {
          map: this.map,
          //analysisGpServer: analysisGpServer,
          showSelectFolder: true,
          portalUrl: this._getPortalUrl(this.privilegeUtil.getUserPortal()),
          showCredits: this.currentToolSetting.showCredits,
          showHelp: this.currentToolSetting.showHelp,
          showChooseExtent: this.currentToolSetting.showChooseExtent,
          returnFeatureCollection: this.currentToolSetting.returnFeatureCollection,
          showReadyToUseLayers: this.currentToolSetting.showReadyToUseLayers,
          isSingleTenant: isPortal,
          disableRunAnalysis: this.currentToolSetting.disableRunAnalysis === true,
          analysisMode: this.analysisMode,
          showGeoAnalyticsParams: this.analysisMode === "bigdata" &&
            this.privilegeUtil.canPerformGeoAnalytics(),
          showBrowseLayers: this.privilegeUtil.isPortal() && this.analysisMode !== "raster"
        //Living Atlas Analysis Layer is not available in portal 10.4
        if(isPortal){
          args.showReadyToUseLayers = false;
        if(this.privilegeUtil.portalSelf && this.privilegeUtil.portalSelf.creditAssignments === 'enabled') {
          args.checkCreditLimits = true;
        if(this.currentToolSetting.title === 'findNearest' ||
            this.currentToolSetting.title === 'summarizeNearby' ||
            this.currentToolSetting.title === 'enrichLayer'){
          args.enableTravelModes = this.privilegeUtil.hasPrivileges(['networkanalysis']);
        if(this.currentToolSetting.title === 'joinFeatures') {
          args.showTemporalJoin = args.showGeoAnalyticsParams;
          args.showJoinCondition = args.showGeoAnalyticsParams;
            this.currentToolSetting.title === 'planRoutes' ||
            this.currentToolSetting.title === 'connectOriginsToDestinations'){
          args.showOutputType = this.currentToolSetting.showOutputType === true;
        if(this.currentToolSetting.title === 'findOutliers') {
          args.enableEnrichmentFields = this.privilegeUtil.canPerformGeoEnrichment();
          args.allowChooseLabel = false;
        if('returnFeatureCollection' in this.currentToolSetting){
          args.showSelectFolder = !this.currentToolSetting.returnFeatureCollection;
        layerUtil.getLayerObjects().then(lang.hitch(this, function(layerObjects){
          //set analysis param
          if (this.currentToolSetting.analysisLayer) {
            // args[this.currentToolSetting.analysisLayer.name] = this.inputLayer;
            args.showSelectAnalysisLayer = true;
            args[this.currentToolSetting.analysisLayer.name + 's'] =
                this._prepareLayers(layerObjects, this.currentToolSetting.analysisLayer.geomTypes);
          //set required and optional param
          var optionalArgs = this._prepareLayerParams(layerObjects);
          lang.mixin(args, optionalArgs);
          try {
            //TODO: fix it, if don't set primaryActionButttonClass,
            //DeriveNewLocations, FindExistingLocations, FindSimilarLocations fails to build ui
            if (this.currentToolSetting.dijitID.indexOf('DeriveNewLocations') !== -1 ||
              this.currentToolSetting.dijitID.indexOf('FindExistingLocations') !== -1 ||
              this.currentToolSetting.dijitID.indexOf('FindSimilarLocations') !== -1) {
              args.primaryActionButttonClass = 'esriAnalysisSubmitButton';
            this.currentAnalysisDijit = new AnalysisDijit(args, domConstruct.create('div', {
              style: {width:'100%'}
            }, this.toolCtr));
            this.currentAnalysisDijit._setTitleAttr(this.currentToolSetting.toolLabel);
            this._bindAnalysisEvents(this.currentAnalysisDijit);
            this.currentAnalysisDijit.startup();
            this.currentDijitID = this.currentToolSetting.dijitID;
            var submitButton;
            if (this.toolCountInList > 1) {
              submitButton = query('.esriAnalysis .esriAnalysisSubmitButton',
                this.toolPanel)[0];
              if (typeof submitButton !== 'undefined') {
                domClass.add(submitButton, 'multiTool');
                var btnDiv = domConstruct.create('div', {
                  'class': 'toolpanel-button'
                //create back button
                var backBtn = domConstruct.create('div', {
                  'class': 'jimu-btn',
                  innerHTML: this.nls.back
                }, btnDiv);
                domConstruct.place(btnDiv, submitButton, 'before');
                domConstruct.place(submitButton, btnDiv);
                this.currentAnalysisDijit.own(on(backBtn, 'click',
                  lang.hitch(this, this._switchToPrevious)));
            //This is the code to set the defaults you are after
            query('.esriLeadingMargin1').forEach(function(node){
              if(node.innerText.indexOf('Routes') > -1){
                setTimeout(function(){
                  var widget = registry.byNode(node.children[0]);
                  widget.set('value', 1);
                }, 300);
              if(node.innerText.indexOf('Include route layers') > -1){
                }, 300);
          } catch (err) {
            console.error(err.message || err);
            domAttr.set(this.toolLoadErrorNode, 'innerHTML',
                jimuUtils.stripHTML(err.message || err));
            domStyle.set(this.toolLoadErrorNode, 'display', '');
          this._switchView(ANALYSIS_VIEW);
          this.shelter.hide();
      }), lang.hitch(this, function(err) {
        domAttr.set(this.toolLoadErrorNode, 'innerHTML', jimuUtils.stripHTML(err));
you also need to add dijit/registry to the define line 6 and 15:
  './toolValidate',
  './PrivilegeUtil',
  './toolSettings',
  'dojo/i18n!./setting/nls/strings',
  'dijit/registry',
  'dijit/form/Button',
  'jimu/dijit/LoadingShelter'
function(declare, lang, html, array, domStyle, domAttr, domClass, domGeom, Deferred, on, Evented,
  query, all, domConstruct, jsapiBundle, JSON, _WidgetsInTemplateMixin,
  esriRequest, JobInfo, FeatureSet, EsriQuery, QueryTask, FeatureLayer, PopupTemplate,
  AnalysisUtils, Extent, BaseWidget, ViewStack, Message, PopupMenu, jimuUtils, portalUtils,
  portalUrlUtils, LayerInfos, layerUtil, toolValidate, PrivilegeUtil,
  toolSettings, settingBundle, registry) {
