raster calculator from model builder to python returning error " 'int' object has no attribute 'save"
1212
05-08-2018 06:28 AM
SimbarasheKapfumo
hie there.
I used model builder to automate my work flow. in the model i used raster calculator tool and it worked perfectly well. when i exported the model to a python scripted, it returned and error : 'int' object has no attribute 'save'.
Is there  a way of correcting the code or an alternative. the code is below. Thank you.
arcpy.gp.RasterCalculator_sa("(\"%FlowAcc%\" > 5000)", Rstream)
i want to select all Flow Accumulation values greater than 5000 and save them to Rstream
DanPatterson_Retired
See your other post
