Esri Utility Network Configuration and Data Loading Tools Status
28483
34
05-03-2018 02:31 PM
HowardCrothers
Network Configuration Data Model Version Last Update Configuration Location Data Loading Tools Location Migration Tools Location
Electric (Distribution & Transmission)4.0May 2021
http://esriurl.com/electricunconfig
https://solutions.arcgis.com/shared/help/data-loading/
http://esriurl.com/elecmigration
Communications1.1May 2021
http://esriurl.com/commsunconfig
https://solutions.arcgis.com/shared/help/data-loading/-
Gas / Hazardous Liquid Pipeline (UPDM)1.2May 2021
http://esriurl.com/gasunconfig
Sewer4.0May 2021http://esriurl.com/sewerunconfighttps://solutions.arcgis.com/shared/help/data-loading/-
Stormwater4.0May 2021http://esriurl.com/stormwaterunconfighttps://solutions.arcgis.com/shared/help/data-loading/-
Water Distribution4.1May 2021
esriurl.com/waterdistunconfig
http://esriurl.com/waterdistmigration
This table shows the current status of Utility Network Industry Configurations and data loading tools.  It will be kept up to date.
Resource specific data models for the utility network are contained in the corresponding Network Configuration.  For example, if looking for the water distribution data model for the utility network download the Water Distribution Data Management for ArcGIS Enterprise.
AnthonyRyanEQL
Hi there,
Where can one find the location of the file geodatabase to download that is the schema, etc of the above configurations? I keep hearing about this with no direction/location of where to find it.
HowardCrothers
What type of network do you want the schema for?  Meaning electric distribution, gas or water distribution.
AnthonyRyanEQL
Howard,
I'm after Electric Distribution & Gas at the moment. In time, I'll be looking for Electric Transmission & Telecommunnications when they become available.
HowardCrothers
You need the asset packages included with these configurations:
esriurl.com/elecdistunconfig
For each of those configurations look under the Get Started tab.  Step 3 is what will give you the asset packages that contains the schema you can load to the utility network.
This explains what is included in the Industry Configurations - https://www.esri.com/arcgis-blog/products/product/electric-gas/introducing-utility-network-configura...
If you need more help let us know.
AnthonyRyanEQL
Howard,
Thanks for this. I'm having trouble with Step 2 in finding the untools with python add in part of ArcGIS Pro. I have asked this question as Plan B to see what can be obtained until this issue of mine is resolved.
RobertKrisher
If you search for untools and nothing shows up, hit the refresh button and try searching again.  I run into that issue pretty frequently when setting up a new machine to do UN work.   Fortunately Esri documented this as a 'note' in their steps 😃
AnthonyRyanEQL
Robert,
I have tried that step several time with no success. Had to install the package manually via the command prompt
DavidHoy
Hi Anthony
going through the initial setup at one of our customer sites and also discovered the untools package was never found to be added.
We found we were unable to Add Python Packages using ArcGIS Pro due to 2 issues
  1. Pro needs to be running with elevated admin rights (UAC environment)
  2. The customer's outgoing proxy is quite restricted and was not allowing access to conda repositories
    1. The following addresses need to be whitelisted to allow the packages to be accessed
conda.anaconda.org
repo.continuum.io
52.216.0.0/16   (AWS S3 buckets)
Hope this helps someone else as well.
RichardDumont
Any Updates on this, it is over 6 months old?  Is this still the correct location?
