Can the CCTV Processor tool be used for MACP (manhole inspections) data?
2214
08-24-2017 03:14 PM
FrankGuillory1
We will be receiving sewer cctv and inspection data from both pipeline (PACP) and manholes (MACP) inspections. I would like to be able to use the CCTV Processor tool for the manhole inspections. Is it possible to use the tool with the MACP data? Would there need to be major alterations to the tool for it to work?
I have attached the access database containing the MACP data.
MikeMillerGIS
Esri Frequent Contributor
The tools only process the PACP inspection data.  We would be interested in extending this to MACP data.  Could you share a sample export of your MACP data?
KimFawcett
Has there been any updates to this CCTV Processor tool for the manhole inspections question? Going to be adding MACP inspections and not sure if CCTV manager would work or if there be alterations to the tool?
