Is it possible to intercept the search widget input?
2476
6
04-28-2018 04:16 PM
DavidAsbury
Trying to figure out how to gather user input without requiring them to input their location twice. I want to end up with both coordinates and a text description of the place.
I have two thoughts:
1) User types location in search widget on geopoint question and input is captured in a text field
2) User types location into a text field and pulldata is used to calculate input for the geopoint question.
Right now I can use a geopoint and pulldata to calculate text fields (a. la. the 'Calculate location from geopoint' sample survey) with coordinates, but of course need a reverse geocode to get place names.
I saw James Tedrick‌'s issue Feedback: Coordinate Entry and GeoSearch · Issue #105 · tedrick/Survey123-Testing · GitHub but was not able to get the example form to work. Probably because I need to do something to set up reverse geocoding so pulldata has something to read - i.e. pulldata("@geopoint", ${location}, "address.text"))
IsmaelChivite
Esri Notable Contributor
Hi. To explore the use of pulldata("@geopoint",${location},"address.text") you should use the Early Adopter cut of Survey123. Also including a short video describing how this works. This functionality is currently in Beta and planned to be made available in version 3.0 around July 2018.
IsmaelChivite
Nielsvan_Rijn2
Hi Ismael Chivite,
Does this feature work already to reverse geocode and get the address? When I use  something like pulldata("@geopoint",${location},"address.text") I get no response.
Thanks, Niels
Nielsvan_Rijn2
RayDanser
When will the pulldata("@geopoint",${location},"address.text") function work? I tried it with the new release and it was not working.
JamesTedrick
Esri Esteemed Contributor
Hi Ray,
During the beta process the exact syntax for accessing reverse geocoding was revised slightly.  Please see https://community.esri.com/groups/survey123/blog/2018/07/06/understanding-reverse-geocoding-in-surve... for updated information.
RayDanser
Got it. Thank you!
