Hi Shana
One option is to create an inbox query that only returns records if you are signed in as the editor.
To do this:
1) Add a hidden question called editor_name (or something like that) to your survey with a default value of the editor's organisational username. This username will be written to all newly collected features.
2) Update the Inbox query where expression to be editor_name=${username}.
3) Publish the survey and get all users to download and update.
This will result in a query that will return no records to the inbox unless you are logged into the device with the username that was populated in the editor_name field.
See the following for more info on the inbox.
Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
I hope this helps
John
