Trying to generate report in Survey123 but get error code 502
2114
04-25-2018 06:46 AM
DavidNykodym
I am trying to generate reports from our field surveys but I keep getting an error code 502. I've attached an image of the error I received. I was able to generate these reports with no issues last month but now have run into issues with this error message. It also seems to be intermittent on when it will or will not generate a report. Has anyone else run into this issue and found a way to fix it?
BrandonArmstrong
Hi David,
We are investigating the error that you are encountering when attempting to generate reports using the Survey123 website.
There has been some discussion and feedback from others encountering the issue in the following GeoNet thread for your reference...
https://community.esri.com/message/767142-re-error-generating-report
Regards,
Brandon
DavidNykodym
Hi Brandon,
Thanks for getting back to me and linking me to the other report concerning this. Let me know if you need any additional information from my side.
