Collaborative Map Notes
1469
04-20-2018 03:41 PM
KrissyLukens
Quick question . . . this is for a group of students. Is it possible for the class to collaboratively edit a map notes layer? Or, even add their OWN Map Notes layers to a collaboratively-edited map? I would prefer to do this over using a Feature Service layer, simply because the students will want to add more to the pop-up than what is possible with the Feature Service layer.
Thanks for the help!
CharlieFitzpatrick
Esri Alum
Krissy, Survey123 can add survey points if desired, if you're looking at adding numbers of points that are the same kind of data. But, if you are interested in collaboratively combining map notes of all kinds (points, lines, areas, different kinds of symbols for different kinds of features with different kinds of attributes), you may find it's not what you seek. In that case, look here:
https://community.esri.com/message/752012-collaborative-mapping
KrissyLukens
Think I may have answered my own question. Survey 123 to the rescue!
CharlieFitzpatrick
Esri Alum
KrissyLukens
Thanks Charlie! While Survey123 may meet my needs, the MAKE A GROUP MAP handout by @geoporters may be the way to go. Appreciate the help!
