How to Delete A Layer From ArcGIS Server Map Service or Feature Service
2243
5
04-19-2018 10:22 AM
BehrouzHosseini
Using ArcGIS Server 10.4.1 I have a published service which looks like
enter image description here
Can you please let me know how I can delete a Layer like Pole(10) from the service?
JonathanQuinn
Esri Notable Contributor
Yes, you're right, it will change the layer IDs for all layers, but you can hard code them within the map document:
Map authoring considerations—Documentation | ArcGIS Enterprise
JonathanQuinn
You'll need to remove the layer from the map document used to publish the service and then overwrite the existing service.
BehrouzHosseini
Hi Jonathan
what I need to do is removing the sequence of 10 (layerId) from the service but still keeping the `Surface  Structure` in with layer ID 11. my understanding is if I republish the service again the new layerIDs will apply to the service layers. so I need to do this trough Server
JonathanQuinn
BehrouzHosseini
Thanks this was what I was missing
MicahBabinski
Good afternoon,
There is a setting in the data frame properties window that allows you to specifically assign (and preserve) the index numbers for your layers:
Once you check that box, you can adjust the index numbers to your liking within the layer properties:
Hope this helps.
Micah
