editing feature class with attached table in ArcGIS Pro
1625
04-16-2018 07:53 AM
ShannonSmith
I would like to edit a feature class in ArcGIS Pro with a joined table. I cannot seem to do this. I can edit the feature class in Pro when the table is not joined. I can do it in ArcMap. Is this a missing functionality in ArcGIS Pro?
Tags (1)
DanPatterson_Retired
It isn't on any of the list updates here
https://community.esri.com/community/arcgis-ideas/blog/2018/02/01/arcgis-desktop-ideas-on-the-move-j...
Since I edit without joins, I don't know if it is or isn't possible.  Have you replicated with the exact same files in ArcMap?
ShannonSmith
Yes, I have edited the exact same files in ArcMap. I kind of need to see the join in order to make the edits to the feature class. It is just a pain to have to remove the join every time I want to edit the feature class. I can't make the join permanent because the data in the table changes every day.
The only other mutterings on the topic were about whether a relationship class was involved and other stuff I don't routinely deal with.
Well at least you can use ArcMap and use Pro for other pressing matters
ShannonSmith
True true. Trying to use Pro for all of my work, this just makes things more difficult;)
