submit survey when question set to Yes
934
04-13-2018 02:57 AM
StuartMoore
So I've got a survey with a lot of questions and depending on the answer to a number of questions changes what would be mandatory questions. i know i cant drive the required field based on logic so i was thinking if i could leave all the questions not mandatory and then have a calculation that sets a final question to 'Yes' but only if all the mandatory questions for that logic have been completed, if not it would get set to 'No'
But then based on this question have it so you couldn't submit the survey until it equals 'Yes'
i guess my question is can i stop the survey being submitted if the answer to the final question is 'No'?
thanks
Stu
StuartMoore
after looking around i have worked out a way to do this using a calculated field and a constraint
hope this helps anyone else with the same requirements
Stu
StuartMoore
Stu
