Pulldata function and Relevant field
979
04-10-2018 11:47 AM
JevitaWebster
im using a pulldata function in my form to populate data base on the value of the previous question. I wanted to use the same CSV file and add another column that will lookup at the value base on the previous question and if the value is 'Y' then i would like the "Grouped Questioned" questions to become visible. Can this be done?
JamesTedrick
Esri Esteemed Contributor
JevitaWebster
yes its the same.  I'm not sure why my pulldata function isn't working in the releveant field.
