Problem configuring Data Store
4034
04-06-2018 07:41 PM
VireshDharmlal
Hi
I have installed ArcGIS Data Store on 2 servers ( primary and a failover Secondary ) but when I try to configure the second data store on the second server,  I get the following error "  Attempt to configure data store failed. Extended error message:  Connection timed out while waiting for the primary data store machine to become available".
The data store on primary site was configured without any error.
Datastore version 10.5.1
VireshDharmlal
Problem solved,
there was a network issue,
by Anonymous User
Not applicable
Happy Friday Viresh. I hope you're having a great day. I just wanted to ask you if you could specify the network issue that was causing the error?
PatrickWard5
You will also get this error if you configure your standby datastore using a different ArcGIS Servcie Account then the one being used by the primary datastore. If this is the case you can uninstall the standby datastore and re-install using the correct account.
