Strange behavior using a JavaScript sample
2434
6
04-09-2018 01:00 AM
CarstenAndersson
Hi.
I'm quite new at using the JavaScript 4.0 API. I've based my page on the sample: ArcGIS API for JavaScript Sandbox. But, when I click between "Scene" and "Map" it behaves strange. Clicking the "Map" on the navigate bar on the top, it changes the to 2D map view and zooms all the way in. Why is that? I then click "Scene" and nothing happens.
I've also tried to just go to the sample page (link above) and run it, and the same thing happens.
Am I doing something wrong?
Any help would be appreciated 🙂
KellyHutchins
Esri Notable Contributor
Looks like this will be fixed in the next release of the SDK. In the meantime I put the working code on jsbin here:
JS Bin - Collaborative JavaScript Debugging
RobertScheitlin__GISP
Carsten,
   There is nothing you are doing wrong. There are errors in that sample that are causing the issue.
khutchins-esristaffalaframboise-esristaff
CarstenAndersson
Hi Robert.
Thanks for the reply 🙂
Are you aware of this being fixed by Esri in the near future? I've search the web trying to find anyone, who has corrected this but didn't find anything.
Carsten,
   I tagged a couple of people that should be able to get this fixed.
KellyHutchins
CarstenAndersson
You saved my day 🙂 Thanks!
CarstenAndersson
Hi Kelly.
I've just noticed that if I try this out in IE 11 the zoom + compass widgets disappears when going from Map to Scene and back to Map.
