Restrict Mouse Hover to layer extent
1947
04-07-2018 07:25 AM
VeenaHosur
I am using mouse hover event to display information,Below code is working but i want restrict mouse hovering to layer extent.If mouse cursor is out of layer extent also graphics and pop is not clearing.Can any help to restrict this
PollingLayer.on("mouse-over", function (evt) { Assemblymap.infoWindow.hide(); dijitPopup.close(dialog); var t = "${POLIN_STATN_NAME}" var content = esriLang.substitute(evt.graphic.attributes, t); highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol); Assemblymap.graphics.add(highlightGraphic); dialog.setContent(content); domStyle.set(dialog.domNode, "opacity", 0.85); dijitPopup.open({ popup: dialog, x: evt.pageX, y: evt.pageY }); }); dojo.connect(Assemblymap.graphics, "onMouseOut", function (evt) { dijitPopup.close(dialog); Assemblymap.graphics.clear(); // Assemblymap.setMapCursor("default"); });
RobertScheitlin__GISP
Veena,
  You are listening for mouse-over on the PollingLayer and then adding a graphic and setting the onMouseOut event to close the popup when leaving the graphic. So your issue is that as soon as you leave the graphic you are likely over the PollingLayer still and the popup is fired again. Why not use mouse-out event on the PolingLayer to close the popup?
VeenaHosur
 PollingLayer.graphics.on("mouse-out", closeDialog);
I have tried with this but its not firing closedDialog
Venna,
  Can you provide all of your code.
VeenaHosur
PollingLayer.setDefinitionExpression("ASBLY_CSTNY_NUM ='" + assemblycode + "'"); Assemblymap.addLayer(PollingLayer); dialog = new TooltipDialog({ id: "tooltipDialog1", style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100" }); dialog.startup(); Assemblymap.on("load", function () { Assemblymap.graphics.enableMouseEvents(); Assemblymap.graphics.on("mouse-out", closeDialog); }); PollingLayer.on("mouse-over", function (evt) { $('#ContentPlaceHolder1_lblmyEPIC').hide(); $('#ContentPlaceHolder1_lblPSName').hide(); Assemblymap.infoWindow.hide(); var pscd = evt.graphic.attributes.PSCode; var assemblycode = evt.graphic.attributes.ASBLY_CSTNY_NUM; var t ="M:" + Male + "  " + "F:" + Female + "
" + "Total:" + Total + "
" var content = esriLang.substitute(evt.graphic.attributes, t); highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol); Assemblymap.graphics.add(highlightGraphic); dialog.setContent(content); domStyle.set(dialog.domNode, "opacity", 0.85); dijitPopup.open({ popup: dialog, x: evt.pageX, y: evt.pageY }); }); function closeDialog() { // alert('hi'); Assemblymap.graphics.clear(); Assemblymap.setMapCursor("default"); dijitPopup.close(dialog); }
I am adding Polling layer after setDefinitionExpression  not whole layer
