back_button how to disable on Android
2477
5
04-03-2018 10:20 AM
MarekFlorianczyk
I'm developing QML application
It seems that "back button" is handled by ArcGIS Runtime for Android
As soon as I add qml runtime to my pro file:
include(/opt/arcgis/runtime_sdk/qt100.2.1/sdk/ideintegration/arcgis_runtime_qml.pri)
I have no control over back button on android.
I'm using V-Play framework which is handling back button, but when I create app with arcgis_runtime_qml.pri back button closes the app immediatelly.
How to disable back button handling by ArcGIS ?
Best Regards
Marek
Tags (1)
LucasDanzinger
Esri Frequent Contributor
I'm not aware of anything in the Runtime SDK that should be affecting this. Were you able to find any clues?
MarekFlorianczyk
Actually, no I haven't found the sollution, I was counting on You Guys
There are some references on back button and  ArcGIS Runtime SDK so I belive this button is handled by ArcGIS
Back button from mapView exits application
handling back button android
Handling back button in Android
The last one does not work for me. Do you want me to prepare running example for testing ?
Best Regards
Marek
LucasDanzinger
Thanks Marek. I've always been under the impression that handling the back button was up to the user, but perhaps I am mistaken. Usually I have added something like the following to perform some behavior when back is pressed:
Keys.onReleased: {
    if (event.key === Qt.Key_Back) {
        // do something
MarekFlorianczyk
Hi Lucas
This is crucial for me, my application is car navigation it cant just shut down when I press back button.
This Keys.onReleased does not work for me, maybe there is some interaction with V-Play framework. I will prepare minimal working example to demonstrate the problem
Best,
Marek
LucasDanzinger
Ok, thanks. If this is a high priority issue for you, I suggest you contact Esri Support or your local Esri Distributor, as they are equipped to troubleshoot these types of things. They can help diagnose the issue, and if applicable, log a bug and hopefully suggest a workaround. This is your best bet to finding a resolution. The GeoNet community will do its best to help make suggestions, but setting up different test environments and troubleshooting high priority issues is best addressed by Esri Support/Distributor.
