handling back button android
1685
02-28-2017 03:54 AM
albavoli
i found the code below:
focus: true // important - otherwise we'll get no key events         Keys.onReleased: {               if (event.key === Qt.Key_Back) {                     event.accepted = true                    //do some action here like close or pop the stack view               }            }
Where should i put this to make it work???
SathyaPrasad
It depends. If you app is simple and only has one main page then you just need to add it in one place. If your page uses Stack view and multiple pages(views) then you need to add this in each page since back might mean close or back for that particular page functionality.
Check the code in Quick Report 1.3 template based app and you will find how its being handled.
