Basemap change Event on api javascript or web app builder
2334
04-03-2018 08:56 AM
GuillaumeArnaud
Hi
I want to check if the basemap is change by another widget. I see that it exist an event on the esri map object but I didn't know how to connect it.
I search one on webappbuilder but I don't find. Does it exist?
Thanks.
Guillaume Arnaud
GuillaumeArnaud
Fine,
I finally check "layer-add" event of map objet.
//Stocke les Basemaps dans une variable pour check le changement
this.bms = ls.getBasemapLayerObjects();
//Surveille l'évenement d'ajout de couche
this.map.on("layer-add", lang.hitch(this, function() {
   //Si le(s) basemaps son modifiées
   if (this.bms != ls.getBasemapLayerObjects()){
      //Parcours les Basemaps
      this.bms.forEach(lang.hitch(this, this.fct_Add_Basemap));
It works.
Thanks.
KenBuja
MVP Esteemed Contributor
You can gain access to the map simply with "this.map" within your widget.
GuillaumeArnaud
Sure, I try this :
dojo.connect(this.map, "onBasemapChange", lang.hitch(this, function(a) {
   console.log("connect");
   console.log(a);
and this :
this.map.on("basemap-change", lang.hitch(this, function(a) {
   console.log("on");
   console.log(a);
but it doesn't work. I don't know how to connect these 2 events because it's ok with other event like click or extent-change.
I change basemap with eBaseMapGallery or BaseMapGallery widget of WebAppBuilder
KenBuja
You're correct. That event isn't fired when the Basemap Gallery is used. You have to listen to the Basemap Gallery's 'selection-change' event. https://community.esri.com/message/84178 This means you'd have to get the Gallery from the Basemap widget and listen for the change.
GuillaumeArnaud
Fine,
It works.
Thanks.
