Are there Size Limitations for ArcGIS for Autocad??
262
03-30-2018 04:54 PM
TonyHowze
I'm running into problems loading complex feature services.  Tile services seem to be working fine, and I've successfully loaded features that are simple, i.e. not many vertices roughly 40k vertices.  I run into problems when the features get a bit more complex, particularly high number of vertices.  I had failed to load a published dissolved layer of 1 polygon, but had a high vertices count (over 300k).  I've successfully loaded a feature service with >500 polygons but < 5k vertices count.
The errors I have seen are "Errors encountered extracting features." after it initializes for awhile.
