Arcpy Describe Function
3009
03-29-2018 06:48 PM
RobertStevens
Why does this function not recognize a project (.aprx) file?
It simply returns that the file is a ....drumroll.....File!
You may say, well, all projects have a .aprx suffix.
Well, map files, afaik, always have a .mxd suffix,
but Describe() has no difficulty in telling you it is a map.
I find this Arcpy API cumbersome and illogical The
omission I allude to here is just one example.
There is no arpy functionality to determine whether
a dataset has a join. There is no API to change a
a field's alias... And so it goes on.
And , while I am on the subject, the documentation has
this really annoying GUI that is slow and is constantly flashing
and redrawing the side bar. It is tiresome, one loses one's
place, and it probably gives people headaches (literal ones).
XanderBakker
Esri Esteemed Contributor
Look at the connectionProperties of a layer and you will be able to see if there are relates or joins. Just scroll down to almost the end of Updating and fixing data sources—ArcPy | ArcGIS Desktop . See the example below of what you will get as a dictionary:
{'cardinality': 'one_to_many',
 'destination': {'connection_info': {'database': 'C:\\Projects\\FGDB.gdb'},
                 'dataset': 'tabular_eco',
                 'workspace_factory': 'File Geodatabase'},
 'foreign_key': 'ECO_CODE',
 'join_forward': False,
 'join_type': 'left_outer_join',
 'primary_key': 'CODE',
 'source': {'connection_info': {'database': 'C:\\Projects\\FGDB.gdb'},
            'dataset': 'mex_eco',
            'workspace_factory': 'File Geodatabase'}}
DanPatterson_Retired
It is the sometimes parallel access to information that might be bothering you
Many data types include properties from other property groups.
I just prefer going by the object or property, then searching here...
http://pro.arcgis.com/en/pro-app/arcpy/functions/alphabetical-list-of-arcpy-functions.htm
or here
http://pro.arcgis.com/en/pro-app/arcpy/classes/alphabetical-list-of-arcpy-classes.htm
Then each module listed here
http://pro.arcgis.com/en/pro-app/arcpy/main/arcgis-pro-arcpy-reference.htm
has their own list of functions and classes.
There are only a couple of 100 things you need to keep straight
EDIT
Noticed tha tXander threw in the API aptly and confusingly named ArcGIS which shares many common elements...
then there is
https://esri.github.io/arcgis-python-api/apidoc/html/genindex.html
And if you only know that it starts with 'arcgis' then you should be good
https://esri.github.io/arcgis-python-api/apidoc/html/py-modindex.html
XanderBakker
RobertStevens
Fantastic! Thank you Xander. It's a pity this didn't exists for Arcmap. But it seems very comprehensive and will help quite a bit.
RobertStevens
Thank you Dan
Those urls describe what appears to be a very rich python API -- far richer than the ESRI description of ArcPy. There are many, many classes. Is that a third party API on githib (or similar)? Perhaps I have not dug deep enought into ESRI documenatation.
