using Pulldata function
736
03-22-2018 10:48 AM
JevitaWebster
Im very new to using survey123.  I just learned how to use the pulldata function.  In the form im working on im using a pulldata function to prepopulate data in one of my fields. In this same form, i would like to use another pulldata function to make a group type visible base on the prepopulate data. Can this be done using the pulldata function?
JakeSkinner
Esri Esteemed Contributor
Hi Jevita,
You can hide/show a field based on another fields value using a relevant expression:
Relevant expressions—Survey123 for ArcGIS | ArcGIS
