Invalid Web Map ID
5409
5
03-20-2018 04:07 PM
Jay_Ehn
I'm new to ArcGIS stuff so this is probably a simple question. I was doing the tutorial for creating Web Maps in the 4.6 Javascript API and thought I'd try to use one of our own portal's webmaps.
However, the end of the url reads as "id=mapidhere". I can't get that to work. I noticed that the ArcGIS examples have "webmap=mapidhere" instead. I'm getting a "message: "Invalid portal item type 'Web Mapping Application', expected 'Web Map'" in the browser console, so I guess the map I'm using isn't right? Is there another way to get the right ID? Thanks.
RobertScheitlin__GISP
Jay,
   If this is your web map you can go to your portal and look at the web map in your content and in the url you will see the web maps id. Since this was not mine I had to watch the browsers network traffic and find the call the app made to the web map.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Jay,
  So you are replacing the "mapidhere" portion with the id of your web map (i.e. e691172598f04ea8881cd2a4adaa45ba)?
Jay_Ehn
Yes. For example, I'm trying the id from this map: ArcGIS Web Application
But it gives me the error message as above. I believe I've configured the esriConfig URL correctly because it seems to be finding something, but it doesn't like it.
Jay,
   That is the id to a web application not the web map that the application is using. This is the web map id d0a88a5528c54dfebb4e009e1a139936
Jay_Ehn
Thanks so much! It's working great now. Can I please ask how you got that other id?
Jay,
