Collector fails to open on Windows 10 without connectivity
2200
03-09-2018 07:40 AM
KevinMcCartney1
Here's the sequence of events and the resulting error I'm seeing. This is with Arc Collector (March 1 download) and Windows 10 (on a tablet).
  1. Run Collector while on our network, log into Online; everything works
  2. Exit Collector
  3. Disconnect the network & disable wifi on the tablet
  4. Attempt to open Collector
  5. The Collector app starts to load, i.e. the app screen is shown briefly, and then it just crashes
How do I resolve this? Thanks.
KevinMcCartney1
This became urgent and was resolved by working with ESRI support.
Resolution - uninstall and reinstall the Collector app. Download all required data again and test.
KevinMcCartney1
RobertBorchert
Honored Contributor
Collector will not work without a network because it needs a network to get data.
you have to prepare collector for offline use.
http://doc.arcgis.com/en/collector/windows/collect-data/offline-use.htm
What kind of Tablet are you using and what is its operating system?
I tend to think it is a table setting.
KevinMcCartney1
Right, Robert. I failed to mention I read that page and did the applicable steps before seeing this error with the app crashing.
FYI It's a Dell rugged Latitude 7212 running and, again, running Windows 10.
