Arcade : Generate Random # Between X and Y
10659
5
03-08-2018 07:20 AM
BrianO_keefe
Honored Contributor
Arcade is excellent. I'm digging in and using it alot. But one of the things I am finding a need for is to generate random numbers. I build a lot of demo maps with fake data. I have to generate fake budgets, fake dates, etc. I generally just 'lorem ipsum' for descriptions but I need to be able to better generate more (close to) realistic numbers.
Does anyone know how I could do this with Arcade?
My preference would be Random(x) to get a number between 0 and X. But that isn't to be.
Anyone?
XanderBakker
Esri Esteemed Contributor
Since Random (Math Functions | ArcGIS for Developers ) returns a value between 0 and 1 you just multiply with the value you want to use as upper boundary:
Random() * X
If you want a value between A and B, you can do this:
Random() * (B - A) + A
XanderBakker
Random() * X
adam_gallaher
This works, but how can one get it to work by generating whole numbers? Currently, this is set up to produce floats or doubles.
Sarah_Saint-Ruth
You can use Round() and set it to 0 to return whole numbers i.e. Round(x,0)
anonymous55
Hello @Sarah_Saint-Ruth @XanderBakker
I need to create new field with unique ID for hosted layer which already published in AGOL. I can't find any Arcade code for creating unique ID for new field in AGOL . I am thinking about to copy object id to new field but I don't know the arcade code for it.
I will appreciate any help
DylanKennard-tt
1/28/2025 - If anyone comes across this and wants to do this in AGOL Smart Forms below is a method to make more of a string. Sort of like a hexcode value. Due to Arcade and not being pure JavaScript its a bit difficult to develop so going basic and simple like the below helps for numbers, letters, or numbers and letters.
///FL = Field Location
var prefix = 'FL';
var letters = 'ABCDEFGHIJKLMNOPQRSTUVWXYZ';
var num1 = Text(Floor(Random() * 10));
var num2 = Text(Floor(Random() * 10));
var num3 = Text(Floor(Random() * 10));
var letter1 = Mid(letters, Floor(Random() * 26) + 1, 1);
var letter2 = Mid(letters, Floor(Random() * 26) + 1, 1);
var letter3 = Mid(letters, Floor(Random() * 26) + 1, 1);
return prefix + num1 + num2 + num3 + letter1 + letter2 + letter3
