JavaScript runtime error: Object doesn't support this action
2481
03-06-2018 10:41 AM
ShaningYu
Honored Contributor
Got error on
<script type="text/javascript" src="http://js.arcgis.com/3.23compact/"></script>
var pt = new esri.geometry.Geometry.Point([-76.99, 38.88]);
Message:  JavaScript runtime error: Object doesn't support this action
What's wrong on this piece of code?  Thanks.
Tags (1)
RobertScheitlin__GISP
Shaning,
  this is your error:
//should be
var pt = new esri.geometry.Point([-76.99, 38.88]);
Shaning,
  this is your error:
//should be
ShaningYu
Honored Contributor
Thanks for you to quickly point out my careless mistake.
