Is there a way to remove a specific character from a string in ArcGIS
6663
13
03-06-2018 02:31 AM
Adil_Toorawa
I have a list as follows;
Object ID        Field 1
1                     Example,Example
2                     ,Example,Example,Example
3                     ,Example
I want to remove just the first comma.
I would appreciate your assistance.
DanPatterson_Retired
lots of ways, but a simple code block might do it
# ---- code block
def func(a):
    if a[0] == ',':
        return a[1:]
    else:
        return a
# --- 'a' is your field name with the python parser, the expression would be
#      func(!YourFieldNameHere!
a = 'Example,Example'
a
'Example,Example'
b = ',Example,Example,Example'
func(b)
'Example,Example,Example'
Adil_Toorawa
Hi Dan, thanks for this however it doesn't seem to work. I replaced 'a' with my field name. I am using field calculator. Do i have to add anything in codeblock?
Set the field calculator to following for the second example
  • python parser
  • make sure that you have activated your new field ie 'newfield
  • !fieldnamehere! is the name of the old field containing the data
  • [!fieldnamehere!, !fieldnamehere![1:]][!fieldnamehere![0] == ',']
And if you are getting an error, then show it.
As for the code block, nothing needs to be changed, but your expression box would call the function with
func(!fieldnamehere!)
Of course, python parser and you are calculating values in a new text field.
Adil_Toorawa
Done it. Thanks.
Adil... perhaps you could mark the thread Answered with the one that provided you the answer so others know a solution was reached and what one was used
Or more simply as a straight field calculation... python parser
replace 'a' with your field name in exclamation marks as above
a = ',Example,Example,Example'
[a, a[1:]][a[0] == ',']
Out[27]: 'Example,Example,Example'
XanderBakker
Esri Esteemed Contributor
In  case you have multiple commas at the start you could use this function in the code block:
def EliminateStartignCommas(txt):
    while txt[0] == ',':
        txt = txt[1:]
    return txt
PeteCrosier
You could also use txt.lstrip(",")
JoeBorgione
And just to play devils advocate....  What about a find and replace for " , "  at the start of the field?
