Is there a way to remove a specific character from a string in ArcGIS
6667
13
03-06-2018 02:31 AM
Adil_Toorawa
I have a list as follows;
Object ID        Field 1
1                     Example,Example
2                     ,Example,Example,Example
3                     ,Example
I want to remove just the first comma.
I would appreciate your assistance.
DanPatterson_Retired
To be completely inclusive
txt = "!A simple question becomes a Monty Python Circus"
['Good','Grief!!!'][txt[0] in '!"#$%&\'()*+,-./:;<=>?@[\\]^_`{|}~']
'Grief!!'
BryanL
Hi All,
I have a somewhat similar question that I have problem solving
Object ID        Field
1                     Apple.
2                     Orange.
3                     Egg
I would like to remove the trailing "." if any. However my code below simply check the string and remove all last characters.
Trim(Left([Field], LEN([Field])-1))
Appreciate any help.
Cheers
PeteCrosier
Easiest way is probably using a Python expression, something like !field!.rstrip(".")
TedKowal
Honored Contributor
IF right([Field],1) = "." then
   [Field] = Trim(Left([Field],LEN([Field])-1))
ELSE
   [Field]=Trim([Field])
END IF
