Understanding Promise deprecation warnings in ArcGIS API for JavaScript?
3411
03-05-2018 02:45 PM
BrienCrean
I am trying to update legacy map code to the latest ArcGIS version of 4.6 and noticed this warning in the console when querying a feature layer.
[esri.core.Promise] DEPRECATED: then() -- use .when(callback, errback) instead
So I tried to change then to when, but got when is not a function errors. I also tried running the sample code from the site and got the same errors.
view.whenLayerView(featureLayer).then(function(lyrView) {
  lyrView.watch("updating", function(val) {
    if (!val) { // wait for the layer view to finish updating
    // query all the features available for drawing.
    lyrView.queryFeatures().then(function(results) {
      graphics = results;
      var fragment = document.createDocumentFragment();
      results.forEach(function(result, index) {
         var attributes = result.attributes;
         var name = attributes.ZIP + " (" +
         attributes.PO_NAME + ")"
         // Create a list zip codes in NY
         var li = document.createElement("li");
         li.classList.add("panel-result");
         li.tabIndex = 0;
         li.setAttribute("data-result-id", index);
         li.textContent = name;
         fragment.appendChild(li);
      // Empty the current list
      listNode.innerHTML = "";
      listNode.appendChild(fragment);
I also tried setting the "esri-promise-compatibility" flag to 1 but that didn't help. Can't see anything in the docs or community forums about this. Anyone come across this before?
Tags (1)
RodrigoFelga
You need to replace then for when just when a class resolve to a promise. I don't see in you code any point to change, maybe the warning came from inside the api. Also happend to me to see warnings that came from inside the api and I can't resolve.
Like
view.then(function(){});‍‍
To
view.when(function(){});‍‍
When a method resolve to a promise you don't need to change.
Read more here: Making Better Promises | ArcGIS Blog
Here is a list of classes that have a then method: Overview | API Reference | ArcGIS API for JavaScript 4.6
