How to rotate labels using Arcade?
3028
03-06-2018 02:02 PM
SarahFox1
My address labels are really hard to read horizontal and would be a lot easier at an angle.  I can't find any examples of using arcade to rotate the labels.  Is this a possibility?  Would there be a different route to get the labels slanted?
Thank y'all very much!
DanPatterson_Retired
I suspect arcade doesn't handle things like rotation according to what is show in this guide.
https://developers.arcgis.com/arcade/function-reference/
but arcade is used in things for symbology etc
http://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/vary-symbology-by-rotation.htm
XanderBakker
Esri Esteemed Contributor
What geometries are you using to label your routes? If they are lines, your labels would follow the line geometry. If they are points, you possibly don't have the rotation information. What software are you using? ArcGIS Pro or ArcGIS Online? Options depend on that too.
