LiDAR data (.las) reference system unknown
1193
03-05-2018 06:34 AM
EvaNougier
Hi everyone,
I have a problem with my data LiDAR (.las). I think the data is in RGF 93 lambert 93 due to their coordinate when I put the .las in CloudCompare. But, when I try to insert .las in ArcGIS Pro, my data is not at their "good" location in the map and when I check the properties, indeed the reference system is unknow.
How can I fixe it ?
My goal is to add a reference system to my LiDAR data in order to have the data in the good place in my map.
Thanks a lot for your answer,
Eva
KoryKramer
Esri Community Moderator
You could try the Create PRJ for LAS https://www.arcgis.com/home/item.html?id=fe221371b77940749ff96e90f2de3d10  The requirements on that page don't specifically include ArcGIS Pro so I'm not sure they'll run directly in Pro.
EvaNougier
I try but I didn't find the appropriate toolbox to fixe my problem.
My LAS data don't go to the right place when I insert the las file.
I put in attached files the properties of my raw files without any transformation.
Thanks for your help,
Eva
