Feature Layer Not Showing
2720
03-02-2018 08:19 AM
GregoryPierce
I've just started with the JavaScript API and I'm trying to add a feature layer per the examples I've found on the API page, but for some reason I am not able to see the layer in the map.  My sample code is below.  Any help trouble shooting this is appreciated.  Thank you.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>FeatureLayer - 4.6</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require(["esri/Map", "esri/views/MapView", "dojo/domReady!", "esri/layers/FeatureLayer"],
function (Map, MapView, FeatureLayer)
var map = new Map({basemap: "hybrid"});
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 11,
center: [-111.99, 41.05] // longitude, latitude
const fl = new FeatureLayer({
url: "http://arcgis.weberbasin.net/arcgiswa/rest/services/CurrentServiceAreas/FeatureServer/0"
map.add(fl);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Gregory,
  Your require array is in the wrong order.
Should be:
require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "dojo/domReady!"],
Notice FeatureLayer is before domReady
Gregory,
Should be:
GregoryPierce
Awesome!  Thanks so much!
