4.x SDK and TypeScript
758
02-23-2018 09:49 AM
JordanBaumgardner
I've been enjoying TypeScript and have been using it more and more in our projects. I've had to look up how to add a TS class to my projects several times now so I thought I'd place it here.
There are two key things that I keep forgetting.
1) It must be compiled in the correct format:
  "compilerOptions": {
    "target": "es5",
    "module": "amd",
    "moduleResolution": "node"
and you must create your class correctly with the export on the last line.
import EsriView = require("esri/views/MapView");
class EventCreatorModule {
    public mapView:EsriView;
    constructor() {
export = EventCreatorModule;
Note: The following will NOT work
// THIS WILL FAIL
export class EventCreatorModule {
    constructor() {
// THIS WILL FAIL
This is my boilerplate
\tsconfig.json
    "target": "es5",
    "module": "amd",
    "moduleResolution": "node",
    "noImplicitAny": true,
    "removeComments": false,
    "preserveConstEnums": true,
    "sourceMap": true,
    "jsx": "react",
    "jsxFactory": "tsx",
    "experimentalDecorators": true,
    "suppressImplicitAnyIndexErrors": true
  "include": [
    "Scripts/**/*"
  "exclude": [
[Empty Class]
class [MyClass] {
    constructor() {
export = [MyClass];
