How to generate map image with Portal Arcgis newPrint tool?
1966
02-22-2018 05:34 AM
CarlosNantes
Hello guys,
I'm struggling with an issue I've encontered after publishing an ortophoto in our Arcgis Server. We don't have Image server extension so I had to publish it as a Mapserver. The mxd is full of references to geotiffs (1800 aproximately). I'm supposing this is the root of the problem.
I have generated the cache for this mapserver and I can view it using Map Viewer of Portal Arcgis. But I can't generate an image of it using the default Arcgis PrintingTools (https://webadaptor.domain/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task).
I have found that if I let the printing tools link blank in my Portal Arcgis Settings, the Print widget of Map Viewer will use another printing tool located at:
https://webadaptor.domain/sharing/tools/newPrint/GPServer/Export%20Web%20Map
(See attached image)
That misterious tool will generate the image correctly, but I can't find it in the docs, so that I learn how to use it.
The PrintingTools of my Arcgis Server won't generate the image and will give the following error response:
   "error":{
      "code":400,
      "message":"Unable to complete operation.",
      "details":[
         "Error executing tool. Export Web Map Task Job ID: [jobidhere] : ERROR 999999: Error executing function.
       Not enough memory to create requested bitmap.
       Failed to execute (Export Web Map).
       Failed to execute (Export Web Map Task)."
I've seen some public Arcgis Servers using that newPrint tool as a GPServer. Does anybody have some info about it?
CarlosNantes
I've realized that the images should be grouped into a single one in a raster dataset before publishing it as a server.
At least the problem is registered now, if anynone has the same issue. To solve that I did the following:
- I've created a Raster dataset in a FileGeodatabase.
- Then I loaded those 1800 tiffs inside the raster dataset.
- I registered the parent folder of the filegeodatabase as a data store in arcgis server.
- Replaced all 1800 references in the mxd to a single one, the raster dataset.
- Finally, I published it on arcgis server.
- I've generated the map cache for the service.
Finally, the Print widget of web appbuilder and the **Export Web Map** woked as expected.
