Selecting features not having attachments from a hosted feature layer
1649
02-19-2018 02:09 PM
DavidLitke
I have a hosted feature layer enabled for attachments. I would like to QA the dataset in ArcGIS Pro to check for features not having attachments. I understand you can use an SQL clause in Pro something like: GLOBALID NOT IN (SELECT REL_GLOBALID FROM MYTABLE__ATTACH), but I can't see the ATTACH table in a hosted feature class.
KellyGerrow
Esri Alum
Hi David,
There isn't an automated way to do this currently.
You could query each item to see if there are any attachment infos and input a flag to easily filter this information in an application.
Check out this sample that Jake Skinner‌ wrote which may have the starting logic that you need Show Attachments in Web Map Popup
REST API Calls:
Attachment Infos (Feature Service)—ArcGIS REST API: Services Directory | ArcGIS for Developers
Update Features—ArcGIS REST API: Services Directory | ArcGIS for Developers
Also, I'd suggest submitting an Idea on https://community.esri.com/community/arcgis-ideas?sr=search&searchId=816c862a-1aea-4488-bb74-3701567...‌ .
-Kelly
KellyGerrow
Esri Alum
Hi David,
REST API Calls:
-Kelly
