Using a reconcile / post in relation to web apps
1537
02-16-2018 09:30 AM
JordanMiller4
I am trying to figure out the best way to create web maps with editing capabilities for our operators out in the field. Similar to a QA/QC type of situation. From what I've read and tried the only way to allow our operators editing access is by creating a version called [Operators] and publishing it with full editing capabilities. Please correct me if there is a better way to do it. And the other thing is the reconcile / post maintenance script we have. The script does a full compression every 2 weeks. Essentially it's deleting all the versions. If it's deleting the version [Operator] does that mean the web map will not work? Does anyone happen to know a workflow that will be useful?
Software:
ArcGIS Enterprise 10.6
Portal 10.6
ArcMap 10.5
import arcpy, time, smtplib, os
deleteVersions = True
reconcileLog = r'C:\temp\Weekly_Reconcile_Log\Reconcile_Log.txt'
# set the workspace
arcpy.env.workspace = 'C:\Users\jnmiller\AppData\Roaming\ESRI\Desktop10.5\ArcCatalog\SDE.sde'
# Set a variable for the workspace
adminConn = arcpy.env.workspace
# Block new connections to the database.
print("The database is no longer accepting connections")
arcpy.AcceptConnections(adminConn, False)
# Wait 15 minutes
#time.sleep(900)
# Disconnect all users from the database.
print("Disconnecting all users")
arcpy.DisconnectUser(adminConn, "ALL")
# Get a list of versions to pass into the ReconcileVersions tool.
print("Getting list of all versions")
versionList = arcpy.ListVersions(adminConn)
for version in versionList:
    if 'default' in version.lower():
        if 'dbo' in version.lower():
            defaultVersion = 'dbo.DEFAULT'
        elif 'sde' in version.lower():
            defaultVersion = 'sde.DEFAULT'
# Execute the ReconcileVersions tool.
print("Reconciling/posting/deleting all versions")
if deleteVersions:
    try:
        arcpy.ReconcileVersions_management(adminConn, "ALL_VERSIONS", defaultVersion, versionList, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_EDIT_VERSION", "POST", "DELETE_VERSION", reconcileLog)
    except:
        reconcileMessage = "Reconcile failed:  " + arcpy.GetMessages() + ".  Check reconcilelog.txt file in the " + str(reconcileLog)
        arcpy.AddWarning(reconcileMessage)
        pass
else:
    try:
        arcpy.ReconcileVersions_management(adminConn, "ALL_VERSIONS", defaultVersion, versionList, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_EDIT_VERSION", "POST", "KEEP_VERSION", reconcileLog)
    except:
        pass
print("Completed Reconcile & Post")
# Run the compress tool.
print("Running compress")
arcpy.Compress_management(adminConn)
print("Compress Completed")
# Allow the database to begin accepting connections again
print("Allow users to connect to the database again")
arcpy.AcceptConnections(adminConn, True)
print("Starting Rebuild Indexes")
# Get a list of all the datasets the user has access to.
# First, get all the stand alone tables, feature classes and rasters.
dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters()
# Next, for feature datasets get all of the datasets and featureclasses
# from the list and add them to the master list.
for dataset in arcpy.ListDatasets("", "Feature"):
    arcpy.env.workspace = os.path.join(adminConn,dataset)
    dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets()
# Get the user name for the workspace
userName = arcpy.Describe(adminConn).connectionProperties.user.lower()
# remove any datasets that are not owned by the connected user.
userDataList = [ds for ds in dataList if ds.lower().find(".%s." % userName) > -1]
# Execute rebuild indexes
# Note: to use the "SYSTEM" option the workspace user must be an administrator.
arcpy.RebuildIndexes_management(adminConn, "SYSTEM", userDataList, "ALL")
print('Rebuild Complete')
# Update statistics on the system tables
print("Updating statistics on the system tables")
# Execute analyze datasets
arcpy.AnalyzeDatasets_management(adminConn, "SYSTEM", userDataList, "ANALYZE_BASE","ANALYZE_DELTA","ANALYZE_ARCHIVE")
print("Analyze Complete")
print("Finished.")
JakeSkinner
Esri Esteemed Contributor
Hi Jordan,
I believe the service that was created from the Operator version will no longer work if that version no longer exists.  You could add onto the script to recreate the version after the compression.  See an example in the below link:
Create Version—Help | ArcGIS Desktop
JordanMiller4
Would I have to republish the feature service after the version gets deleted and recreated?
JakeSkinner
You will most likely have to restart the service.  Take a look at the following tool.  It is similar to the script your running but it also stops/starts your ArcGIS Server services:
https://community.esri.com/docs/DOC-9914-compress-geodatabase-tool
