Filter table to map extent in the web interface
1631
02-15-2018 07:41 AM
JAVIERVARA_SANZ
In the data screen on Survey123.com, Is there of way, or are there any plans, to filter the data below the map based on the map extent? I'm thinking about a toggle similar to that use to "Show individual response".
Thanks.
BrandonArmstrong
Hi Javier,
The dynamic filtering of data in the table based upon the map extent is not currently possible within the survey123.arcgis.com website, however, you can accomplish this using ArcGIS Pro.
Filter data in the table—ArcGIS Pro | ArcGIS Desktop
I will make note of your request in our backlog.
Brandon
JAVIERVARA_SANZ
Thanks Brandon.
I am using custom templates and expecting the feature service to have quite a large number of records. At this point interacting with the map will be my best option. However, I believe implementing a filter by map extent will be highly valuable.
Thanks again.
ahargreaves_FW
I now have this need and am wondering if anything has changed in the interim time period to let me maybe pulldata() the @extent of an @geopoint map?
@IsmaelChivite  or @JamesTedrick  or @Anonymous User
