Creating feature layers from custom data
3066
02-14-2018 05:38 PM
ZoltanBordas
I am sorry for the previous confusion, let me try to go into more details. I am trying to create a group layer and feature layers under the group layer. The source of the data is an outside source and the data is streamed into the plugin implementation through some TCP/IP based protocol. I have all the information (like XYZ) to create (for example) point features in a new, customized feature layer. When doing the same in ArcMap and in the old ESRi API we:
1. Created a new feature layer: IFeatureLayer newLayer = new FeatureLayerClass();
2. Created a new feature class and built up the field information IFeatureClass newClass = .... using esriGeometryType.esriGeometryPoint,
3. Set the feature class on the new layer. newLayer.FeatureClass = newClass; newLayer.Name = ...; newLayer.Visible = true;
4. Added it to the previously created group layer. groupLayer.Add(newLayer);
I am trying to replicate the same logic using the new ArcGIS Pro SDK and I'm having trouble getting the same result.
Zoltan
Tags (1)
Wolf
by Esri Regular Contributor
Hi Zoltan,
 This workflow is now a bit more complicated because you have to use a GP Tool to create a new feature class, and then you can add that feature class as a layer to your group in your map's content.  Below is a code snippet that will do this - I collected the code from various ArcGIS Pro SDK community samples.  Just create a new project with a blank map, add a button with the code below and it should add a group and your new feature layer within that group.  Since the GPTool also creates a new feature layer in your map you need to remove that feature layer since it's now in the new group.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using ArcGIS.Core.Data;
using ArcGIS.Core.Geometry;
using ArcGIS.Desktop.Core;
using ArcGIS.Desktop.Core.Geoprocessing;
using ArcGIS.Desktop.Framework;
using ArcGIS.Desktop.Framework.Contracts;
using ArcGIS.Desktop.Framework.Dialogs;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
namespace ProAppModule1
     internal class Button1 : Button
          protected override void OnClick()
               MakeFeatureClassInAdd2Group("MyPoints", "MyGroup");
          private async void MakeFeatureClassInAdd2Group (string fcName, string grpName)
               Map activeMap = MapView.Active.Map;
               // create the new Featureclass
               var gpResult = await CreateLayer(fcName, "POINT");
               if (gpResult.IsFailed)
                    MessageBox.Show($@"Error {gpResult.ErrorCode} in GP Tool: {gpResult.ErrorMessages}");
               await QueuedTask.Run(() => {
                    // create the group layer
                    GroupLayer grpNew = LayerFactory.Instance.CreateGroupLayer(activeMap,
                         0,  // add to the top ?
                         grpName);
                    // add the newly created feacture class as a layer to the group
                    var fcPath = System.IO.Path.Combine(Project.Current.DefaultGeodatabasePath, fcName);
                    LayerFactory.Instance.CreateFeatureLayer(
                         new Uri(fcPath),
                         grpNew,
                         layerName: $@"{fcName} - 1");
               // TODO: delete the layer which was added by the GPTool
          /// <summary>
          /// Create a feature class in the default geodatabase of the project.
          /// </summary>
          /// <param name="featureclassName">Name of the feature class to be created.</param>
          /// <param name="featureclassType">Type of feature class to be created. Options are:
          /// <list type="bullet">
          /// <item>POINT</item>
          /// <item>MULTIPOINT</item>
          /// <item>POLYLINE</item>
          /// <item>POLYGON</item></list></param>
          /// <returns>Result of GP operation</returns>
          private async Task<IGPResult> CreateLayer(string featureclassName,
               string featureclassType)
               List<object> arguments = new List<object>
        CoreModule.CurrentProject.DefaultGeodatabasePath, // use the default geodatabase
        featureclassName, // name of the feature class
        featureclassType, // type of geometry
        "",                                        // no template
        "DISABLED",                    // no z values
        "DISABLED"                    // no m values
                    arguments.Add(SpatialReferenceBuilder.CreateSpatialReference(3857)); // Projected Coordinate System     WGS 1984 Web Mercator Auxiliary Sphere
               return await Geoprocessing.ExecuteToolAsync("CreateFeatureclass_management", Geoprocessing.MakeValueArray(arguments.ToArray()));
ZoltanBordas
Wolf,
Thank you very much for the directions. Now I use the GeoProcessing API call to create the feature class and after locating it in the map's layer collection I can move it under the group layer I previously created (I will handle possible duplicates):
                // Find the new layer in the root folder of the map.
                Layer newLayer = activeMap.Layers.First((layer) => layer.Name == layerName);
                // ...  check for errors.
                // Move the new layer to the group Layer.
                await QueuedTask.Run(() => groupLayer.MoveLayer(newLayer, 0));
Now I have the feature class element under my group layer and it is exactly what I need at the moment.
Zoltan
