Convert features with the same code to a KML file
6491
17
02-07-2018 01:13 AM
DanutaHodgson
branched from https://community.esri.com/thread/207867-how-to-automate-selection-and-kml-conversion
 I need to do something similar but for areas.
However I have arcmap10.0 and I cannot get this script to work.
Could you please assist me.
I need to select multiple attributes that have the same name in the AA_area field and export them as a Kmz.  I then need it to choose the next area and repeat.
EG. Alexandia is in the attribute table 10 times under AA_area and I would like it to export all 10 polygons into one kmz (this is a shapefile in need to convert from).  I need to do this for all the different areas in the AA_area field.
Thank you for your help.
Tags (3)
XanderBakker
Esri Esteemed Contributor
Hi Danuta Hodgson ,
What you will need to do is:
  • On line 7 locate the path to your input shapefile like this:
    fc_in = r'C:\Folder\SubFolder\myShapeFileName.shp'
  • On line 8 you will have to specify the field with the names. For each name a KMZ will be created:
    fld_trail = 'AA_area'
On line 9 you will need to specify the output folder location where the KMZ files will be stored:
    out_folder = r'C:\Folder\SubFolder\ResultingKMZfolder'
Since you are using a shapefile your where clause will be different. So change line 17 to this:
        where ="\"{0}\" = '{1}'".format(fld, trail_name)
It is important that the indentation remains the same. Changing it will make the code invalid.
DanutaHodgson
Thank you for coming back to me.
I tried what you said, but absolutely nothing happened.
Please could you double check
Also should train name not be changed to AA_area?
def main():
... import arcpy
... import os
... arcpy.env.overwriteOutput = True
... # settings: edit these
... fc_in = r'C:\Users\Danuta\Desktop\CSS 2016-17\TEST\Agri\Agri_EC_working_data.shp'
... fld_trail = 'AA_area'
... out_folder = r'C:\Users\Danuta\Desktop\CSS 2016-17\TEST'
... # create list of unique trail names
... lst_trails = list(set([r[0] for r in arcpy.da.SearchCursor(fc_in, (fld_trail))]))
... # loop through trails
... for AA_area in lst_trails:
... fld = arcpy.AddFieldDelimiters(fc_in, fld_trail)
... where ="\"{0}\" = '{1}'".format(fld, trail_name)
... arcpy.MakeFeatureLayer_management(fc_in, "lyr", where)
... kmz_file = os.path.join(out_folder, "{0}.kmz".format(trail_name))
... arcpy.LayerToKML_conversion("lyr", kmz_file)
XanderBakker
I'm going to branch your question to a new thread. It would be better if I have access to (a subset) of the data you want to use. Can you attach the shapefile (zipped) to this thread?
XanderBakker
I notice that you didn't copy the entire code. The part that starts the code was not included. You should copy and paste the entire code below:
def main():
    import arcpy
    import os
    for trail_name in lst_trails:
if __name__ == '__main__':
    main()
DanutaHodgson
I have copied the above text into python in arc and I got a runtime error.
I am using ArcGIS 10.0
>>> def main():
... import arcpy
... import os
... for trail_name in lst_trails:
... if __name__ == '__main__':
... main()
Runtime error <type 'exceptions.AttributeError'>: 'module' object has no attribute 'da'
XanderBakker
OK, I see. At 10.1 the arcpy.da cursors were introduced, so the old cursor object should be used. I will post back a revised script.
XanderBakker
Try this:
def main():
    import arcpy
    import os
    lst_trails = []
    cursor = arcpy.SearchCursor(fc_in)
    for row in cursor:
        lst_trails.append(row.getValue(fld_trail))
    del cursor
    del row
    lst_trails = list(set(lst_trails))
    main()
DanutaHodgson
Hi, thank you for helping me out.  I really suck at scripts.
I ran the script and and and ArcMap Drawing Error saying one or more layers failed to draw:
lyr: An invalid SQL statement was used.
Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000622: Failed to execute (Layer To KML). Parameters are not valid. ERROR 000625: layer_output_scale parameter has no default value.
Should there be changes in the script. Could you tell me what and I can change them?
Really appreciate the help
XanderBakker
Possibly, something related to the data is happening here. To avoid guessing, I really would need to have a look at the data. Can you share it?
