arcgis javascript imagery layer refresh method
1769
01-27-2018 02:15 PM
DavidPuckett
As of version 4.6, the arcgis javascript API does not support a refresh method on a layer in a 3D scene view (only supported in 2D map view). See 'Known Limitations' here
ImageryLayer | API Reference | ArcGIS API for JavaScript 4.6
So I thought I'd share what I've found as a workaround. You simply set the layer visibility to false then set a zero length timer to set it back to true (it does not work to set it back to true without the timeout, for whatever reason).
A sample:
activeImageryLayer.visible = false;
window.setTimeout(function() { activeImageryLayer.visible = true; }, 0);
The downside here is that it does visibly 'flicker' the layer when it is turned off. This is acceptable for my project but is still a little janky.
I'd be interested to hear what others have implemented as a workaround for this glaring omission from the API.
JohnGrayson
Esri Alum
I can't recall the exact details, but I think I've used this in the past:
view.extent = view.extent;
