Error: 500 Upgrade 10.5.1 to 10.6 ArcGIS Server
2634
01-25-2018 01:59 AM
Luiz_AmadeuCoutinho
Hi Guys
Yesterday I did the upgrade of ArcGIS Server 10.5.1 to 10.6.
The 10.6 was upgrated , authorized and all services were migrated and All services are running. But I got the msg bellow when I tried to see my rest services .
Error: Error handling service request :Could not find a service with the name 'myservices' in the configured clusters. Service may be stopped or ArcGIS Server may not be running.
Code: 500
Here the server Diagnostic Tool.
ArcGIS Server 10.6 on Linux Single machine
ArcGIS Server 10.6.0 Diagnostic Tool
                       Hostname: xxxxx.com
 DIAG000: Check for installation as root                       [PASSED]
 DIAG001: Check for 64-bit architecture                        [PASSED]
 DIAG002: Check OS version                                     [PASSED]
 DIAG003: Check hostname for invalid characters                [PASSED]
 DIAG024: Check /etc/hosts for hostname entry                  [PASSED]
 DIAG004: Check installed packages                             [PASSED]
 DIAG005: Check system limits                                  [PASSED]
 DIAG008: Check HTTP port                                      [PASSED]
 DIAG009: Check HTTPS port                                     [PASSED]
 DIAG010: Check Xvfb ports                                     [PASSED]
 DIAG020: Check hostname IP address mismatches                 [PASSED]
 DIAG026: Check processes for ArcGIS core services             [PASSED]
There were 0 failure(s) and 0 warning(s) found:
RandallWilliams
Question:
Is 'my services' a folder containing other services, or is this itself a service?
Are you able to open and see the rest endpoints for other services, like in the 'system' folder?
Luiz_AmadeuCoutinho
Hi Randall
"myservices" it´s a sample.
You can see the error here http://arcgis.fc.ul.pt:6080/arcgis/rest/services
Luiz_AmadeuCoutinho
FIXED
After contact the local distribuitor , the solution was:
 - Backup of all services using the backup utility
 - Uninstall the Server 10.5.1 (installed on non default folder)
 - Install the Server 10.6 on different Folder ( default folder /home/arcgis)
- Import site via server/admin
Now it´s working on https
