web appbuilder developer app import fails
4673
9
01-23-2018 10:26 AM
JayHodny
I have installed Web AppBuilder Developer 2.7.  I am working with Esri's public parking solution.  The 'Import App' fails to import this application.  Other applications will import.  The command window (log) shows no useful information (to me) as to why the application not import.  Also, if I use the 'Delete' on imported apps, does this delete them from my AGOL content?  Thank you.
Tags (1)
JayHodny
Robert,
Tech support was able to help.  I downloaded the (zipped) app from AGOL to my desktop, and was able to import it from there.
Regards, Jay
RobertScheitlin__GISP
Jay,
   The public parking solution template is NOT a WAB app it is a esri configurable template application.
JayHodny
Hi Robert,
Thanks for the quick reply. I am confused. I assumed it is a Web AppBuilder product, based on the screenshot.
Regards,
Jay
Jay,
   Sorry I am incorrect. It seems that the solution team has provided this as a WAB app. Do you know the version of the app that you are attempting to import?
JayHodny
Hi Robert,
I don’t know the app version, how can I determine that? I was using an older version of WAB, and was receiving a ‘fail to import’ error. The error note directed me to upgrade to the most recent version (2.7) of WAB.
Thank you for your help!
Jay
Jay,
   Open the zip file and then the env.js file in a text editor. In that file you will find the deployVersion = '2.x';
JayHodny
Hi Robert,
//This version number will be appended to URL to avoid cache.
//The reason we do not use wabVersion is to avoid force user to change wabVersion when they are customizing app.
deployVersion = '2.7';
Jay
Jay,
   Then it does not make sense why it won't import. I would get tech support a call.
JayHodny
Hi Robert,
I agree. I can open other apps, but not this one. Thanks for your help.
Regards,
Jay
JayHodny
Robert,
Regards, Jay
